Originally Posted by StevieC
No OE isn't without their faults at times. YES TOYOTA, I was picking 2 examples to better illustrate my point. I didn't point to specifics, that's something you did.
Right, but we all know that the HF V6 is the example, so why not mention it? There's no virtue in beating around the bush, we all know what GM screwed up. Their LSx series engines on the other hand, seem to be generally excellent.
Again what I was getting at is one OE (Toyota) seems to do their research before the run with something and the others let the market work out the bugs it would seem continually. Cough Cough GM.
Look more at the history of these two companies with regards to oil requirements and engineering issues requiring oil changes to remedy the problem.
As much as I am not a GM fan, I think that's unfair. While GM does have a history of goofs that's perhaps longer than Toyota's, it ignores the generally excellent track record many of their products have had. Toyota has had both oil control ring return hole problems, resulting in consumption and burning, as well as significant sludge issues which resulted in a class-action lawsuit when they denied it. Yes, they stepped up to the plate on the frame replacement for the Tacoma and Tundra, but again, there was a class-action lawsuit about that too IIRC. Then there was the saga of the unintended acceleration.
Specifically, GM's "oil change remedy" was for the HF V6, and it didn't fix anything because it was a design issue with the engine. It was an attempt to bandaid an issue I'm sure they were well aware of at that point. Prior to the Dexos revenue racket, GM's oil specs were primarily for the Corvette, which I don't think is unusual
