OK, so I added half a quart of MMO to my oil tonight. I have been reading about adding MMO to oil for a week now. I have been adding it to the gas every fillup, 4 oz to 10 gallons like they say. I got some really good results from that, a better idle, a bit more power and just an overall more smooth running engine. This is on a 2001 Dodge Dakota with nearly 122,000 miles on it, 3.9 V6 with a 5 speed manual. I use Napa or Carquest house brand 10W30 conventional and Proselect or Carquest Red filters. Truck runs very well with them. My truck is almost 1000 miles shy of its next oil change and I could not wait any longer to try MMO in the oil.
So, I added half a quart MMO to the crankcase and headed out to run a few errands around town tonight. Maybe 12 miles total but I made a few stops. I noticed when I started the truck it ran a lot quieter and was had such a smooth idle I had to roll down the window to listen if the engine was really running. I headed on out and noticed a bit more power when driving, nothing to get too excited about, but it felt good. Then I stopped for gas, popped the hood and my engine was running very very quietly, mostly the only noise was from the pulleys on the alternator, idler pulley and belt tensioner. It was running like a sewing machine, as some might say. A very well-oiled and well lubed sewing machine. So I filled up the tank and when I started the engine it only took a split second blip of time to crank. Less than a second and it started and was running fine. Before MMO, it would always take maybe a second and a half to turn over and crank. We have had a bit of cold weather here in Florida lately and the last few mornings it has taken about 3 or 4 seconds to start. Morning temps have been around 40 to 50 degrees. Two nights ago it got down to freezing for a few hours about 25 miles north of here. Anyway, I made 4 or 5 stops tonight and at each one, the truck was starting almost instantly when I hit the ignition. And it really is running very smoothly. It used to have a little bit of a shudder I could feel at idle, nothing wrong or detrimental, not even enough to affect the RPMs on the tachometer - just a little vibration that is said to be common in the 3.9 V6. With only half a quart of MMO in the oil, that shudder is completely and totally gone now.
I will see how it starts in the morning when I head out to work, and see if there is any improvement in 60-70 mph highway driving during my commute. But to say I am very well pleased and impressed with MMO is putting it very lightly. This stuff works very well, and it does what it says it will. I'm not looking for any miracles here, just trying to take good care of my truck and get the best performance and MPG I can. I am still getting right at 17 MPG with MMO in the gas but that may do better when the weather warms back up and may do even better the longer I run the MMO in the oil.
I was planning to only use MMO in the oil during the last 1000 miles of my OCI as a cleaning agent, but if the gains and improvements I get from MMO are consistent, I think I will start putting in 3.5 quarts oil and half a quart MMO every time I change my oil. I worry a bit about how much a whole quart of MMO will thin out the 10W30 I use so I am a bit hesitant to use a whole quart in the oil.
But man, this stuff really does work! I really don't think it's psychological or placebo effect. I know my truck like the back of my hand. MMO works. I can't believe how much smoother, quieter and better my engine is running with it. Anyone who is skeptical like I was should at least try half a quart in the oil and try it in the gas too.
Now I just need to find a place that sells it by the gallon. Walmart here doesn't have gallons of MMO, but I guess they could order it. I'm keeping my eyes open for a BOGO or a good sale on it at any of the parts stores.
So far for my truck, MMO works great.
