i wouldn't use Vavoline/Pennzoil/RP/Neo and all the boutique stuff. I like Chevron, Mobil, Red Line, Havoline and Castrol personally.
Other than the fact that Redline may or may not be boutique oil itself.....why would you not use Pennzoil, but use Castrol?quote:
In my mind it isn't about the cost, it's about out and out lying to your customers by redefining the word "synthetic" because you knew you could get away with it in a given market. Depends on how you define "is" right?quote:
Originally posted by Audi Junkie:
Exactly what I was going to say. Bogus Syntec 5w-30 is probally overkill for 95% of the cars on the road.
I guess the way to be successfull in the oil industry is make the most expensive product at the cheapest price, by your logic.Is buying overpriced PAO from a competitor when an excellent substitute is available really so brilliant? Should Castrol still be using caster bean oil by the boatload? What if Castrol put the 2 cents a quart saved on PAO into R&D...bringing us a great product like GC? Is it ok now?
Red Line is readily available in the Bay Area. I just don't like Pennzoil, primarily because they just sell a lot of gimmicks to people.quote:
I'm not one of the guru's, but I am a disgustingly cheap convenience store shopper, and you can buy SL Shell Clean Formula 10W-30 at Dollar General for $1; and a really fine CITGO SL 10W-30, 10W-40, and 30 grades at Dollar Tree stores for $1.quote:
If you are a self-proclaimed "oil guru", you would never use any no-name, off-name, store-name brand of oil, or .99 cent convenience store oil.
LoL, I been using the Mobil-1 0W30-R which isn't API and I bet it's one of the best 0W30 oils out there with the possible exception of the AMSOIL S2K 0W30. Isn't that not API as well?quote:
Originally posted by Ugly3:
Avoid all oils that are not API certified. "Starburst", buy - no "Starburst", stay away.
If you look at the specs on most 10w40 dino oils though, you'll see that most of them are thin 40wt oils around 13.5 cst at 100c. So they aren't all that much thicker than your typical high mileage 10w30 (which is around 12 cst in most cases) I don't think the latest versions of 10w40 use as much VII in them as the stuff from the 70s and 80s.quote:
Tall Paul -
I have never seen a car maker that recommends "only" 10w40 motor oil for a vehicle. What I have seen is temperature ranges with several oil options that cover the various temps. In most cases 10w30 covers the temp range for all but the hottest temps in which case you should be using 15w40 anyway.
My "real world" answer is to use a good synthetic 5w30 or 5w40 the year around and forget about it.
Remember the reason 10w40 dino got all the bad rap? Something about the viscosity extenders "burning up" or "crystalizing"in the engine and fouling up the rings. That is why almost no car maker recommends 10w40 dino any more. I don't want any of that **** in my engine in the first place.
I admit, I can't point you to such. My F150 "takes" 10w40 because that's what I give it.quote:
My only argument here is price, but of course there is always Rotella, if one is willing to go HDEO.quote:
What Patman said. BTW, I am looking to get a thicker 10w40 than the current 14 cSt I am using.quote:
The arguments I recall from this site are "weak add pack" and "overpriced." I don't know that the add pack is any "weaker" than a lot of other oils out there, but for a lack of moly maybe. But for the record, you can chalk me up as a Valvoline user: I have 54 quarts of Maxlife, Synpower, and Durablend at home.quote:
Several folks here have mentioned that they would not use Valvoline oils. Why?
