OK...
New lawn mower 6.75 HP Briggs.
On the way home I mentioned to my wife, "You won't believe me, but I don't have the right oil."
I had looked at the owner's manual on-line before purchase--Sears. It calls for SAE 30 over 32degrees F.
I DO have other weights -- 5W30, 10W30, 5W40, 15W40, and 20W50.
It said if you use a multi-weight oil, expect oil consumption.
Turns out it came with some oil for the first fill, and I used that.
I don't mind getting some new oil for it in 30, but does anyone really think it will matter much ?
Pre-BITOG, I would have put in what I have and not worried. OR-- Gotten the SAE 30, and not assumed that I know anything.
My old mower, Briggs engine, just crapped out and won't stay running. Before the last couple uses, it hadn't so much as hiccuped since 1979. I think it needs valves, compression is low. New engine or short block just didn't look as good as a new one economically.
