I started as a Castrol GTX fan buying their hype about "Maximum protection against viscosity and thermal breakdown" which sounds nice but is just a bunch of B.S. mumbo jumbo. I used that from the mid-eighties up until some time in the early nineties when I began using their Syntec and occasionally Mobil 1 in my '90 Acura Integra.
Sometime before I got rid of the Integra and bought the '95 Civic, I figured that Valvoline was the best dino available and used that to break the car in. I figured that Ashland was the refinery which made all the Valvoline products and I always assumed that a refiner would be better than a mere blender. Couple this with Valvoline's impeccable reputation … albeit among people fairly ignorant about oil.
Along the way, Mobil 1 fed me some internet hype about Castrol Syntec being not-quite-as-good as M1 and I switched. In fact 90% of the miles I put on the Civic were with Mobil 1; “regular” and “Tri-Synthetic.” Worked OK most of the time but the piston-slap racket in the cold was becoming unbearable.
I tried Valvoline Synpower when it came out as it was supposedly a PAO and supposedly had more ZDDP than Mobil 1 Tri-Syn SJ. But, Valvoline was a disappointment as the engine which had not needed top-off oil all its life began consuming nearly 1 quart in 5,000 miles.
The first batches of Max-Life were pretty good. Lots of moly but the base oil was not as good as their techs claimed.
I’ve pretty much had it with Valvoline.
I tried Red Line and results were pretty good. Wear was OK after extended use … but testing showed the beginning of a coolant leak. On the bright side, consumption returned to zero after even 7,000+ miles.
This is the time I discovered BITOG. Now it’s Schaeffer, Chevron, Red Line & Pennzoil and for me.
--- Bror Jace
--- Bror Jace
