Greetings everyone,
I don't think I have an issue, but I wanted to run it by you folks just to double-check. On the last oil change on my '01 Grand Marquis (standard 4.6L and unfortunately no PI motor ), I switched over to Pennzoil Platinum after the car used conventional for at least most of it's life. (Valvoline conv. was used in the previous OCI)
The switchover to PP happened 2 months and 1400 miles ago, so you can see the car doesn't see much mileage now. I just checked the dipstick a few minutes ago and saw that it used up less than half-a-quart (which is more than usual for THIS car, but I believe it's still in the range of normal consumption) and the oil had a golden-brown color. The car has no leaks that I know of and the clock shows 164k miles.
Now from previous topics, I believe that it has been proven that the engine will initially use more oil when you switch from conventional to syn, but then the consumption goes down after. I would imagine that different engines have different results, so I was wondering if anyone had an idea about how long it would take before the consumption goes down? I am planning on going 6 months or 7500 miles on this OCI, unless anyone thinks that I can exceed it.
Thanks for your help everyone!
