Originally Posted By: 901Memphis
The rated viscosity is tested at 100C, so 100C is "ideal" , although a tad higher might be better for getting rid of condensation.
It is not needed for the temp to exceed 212 F to boil off moisture. There is significant effect at much lower temps, 180 F is actually fine unless you have a water issue like a leaky head gasket or such!
