ive had 2cycle unopened oil bottles leak after cold temps, i wouldnt use it myself, those small bottles are sealed differently than 4cycle quarts tho, oil filters rusting is a bigger concern, i always keep them inside
Let's say that it was possible.
Why would it matter?
You'd put the oil in an engine, and the first time the engine was run up to operating temperature for a decent length of time, all of the moisture would be evaporated out of the oil.
I used to be pretty anal about storage of my filters and oil. Then I realized - I dump it in a car, which then exposes it to more heat (and more cold, since I park outside in the winter) than anything I could do to it letting it sit in the garage.
I expect oil to operate in the harsh environment of my engine and climate. Why would I not expect it to operate in the (relatively) mild environment of storage?
Originally Posted By: pbm
NO.
But I don't like storing oil in an unheated shed etc..because the constantly changing temperature degrades the oil faster,IMO.
I would doubt that. Can you site a source for that information?
NO.
I did read (somewhere.. long ago) that 68*F was optimal for oil storage. I don't think a few months in an unheated shed would do much harm but a couple of years might.
I would think that the constantly changing thermal cycle (from 0* to 100*F) is causing the additives (VII's) to 'work' while not even inside the engine.....I would like to hear Molecule or Tom in NJ or somebody more technically knowledgeable comment on this...
I'm not a tribologist but I play one on TV....
I may need to move some of my stash to the unheated outdoor shed for a year or 2. I may even make a storage under deck and keep them there, since it's dry. I hope the humidity in the unopened bottle are low enough that winter temperature remain it's dew point (inside the bottle).
