Originally Posted By: dave1251
Originally Posted By: rrounds
Originally Posted By: Clevy
You don't need high zddp. If you did I'm sure chev would have had Mobil mix something up for it.
If warranty isn't an issue then I suggest red line or amsoil or pennzoil or any name brand 30 grade. That engine is roller everything and not really overly hard on oil. Personally I'd use a conventional changed at 5000 miles so I could monitor oil colour and smell etc.
I'm sorry but the Fed's won't allow high ZDDP in oil's for cars today. Truck oil has been changed too, by order from the Fed's.
ZDDP lube parts in the engine other than the lifters, if you don't use oil ZDDP will not hurt your cats. If you burn a lot of oil then yes it can and will shorten the life of the cats. I use a mix of Mobil 1 0w50 racing oil and Mobil 1 Advanced Fuel Economy 0w20 in my S2000 but if my engine used oil I would go with Mobil 1 0w40
Do you actually believe what you posted?
I believe I should change my career direction there is a lot of money to be made by fleecing consumers.
Yes I do and here is just one mag that says the same thing
"Recent Oil Formulation Changes
Auto manufacturers have been required by federal law to warrant specific components of the emissions control system on any '95-or-newer car or light-duty truck for the balance of eight years or 80,000 miles--including catalytic converters. In that time, it has been determined that phosphorus in exhaust can negatively react with the converter's active catalysts, rendering it inoperable. The cost of component replacement cannot only fall upon the manufacturer, its failure can also create a vehicle that excessively emits pollutants until said repair is made.
The largest amount of phosphorus inside an engine is in its oil. A compound molecule named Zinc Dialkyl Dithiophosphate (ZDDP) is comprised mostly of zinc and phosphorus, and has long been a common antiwear oil additive. ZDDP offers key frictional-heat-activated qualities that form a sacrificial chemical barrier on components that are under continuous high-pressure contact. While much of the oil would literally be squeezed from between the components in these conditions, ZDDP prevents the metal-on-metal contact that could otherwise result. A classic example would be a camshaft lobe and lifter.
Since phosphorus has been proven to negatively affect catalytic converters, auto manufacturers and oil companies are working to find a suitable antiwear additive to replace ZDDP. But that has been a major task. So, until it happens, the analysis organizations have imposed a temporary limit on the maximum amount of ZDDP in oil--no more than 0.01 percent by weight. It appears this reduction has had a major effect on the hobby since its enactment in January 2004.
Read more:
http://www.highperformancepontiac.com/tech/hppp_0606_understanding_motor_oil/viewall.html
and this is from M1 web site
Question:
Has Zinc Been Removed from Motor Oils?
I am having thrust bearing failure in a 4.6 modified performance engine. This is a street/strip engine. Many of my friends are having the same problem. I think it is the result of the removal of zinc from the oil. I was told by two separate racing engine builders that the EPA ordered the removal of the zinc from over-the-counter motor oil. I use Mobil 1 5W-20. Is this true and do you think a zinc additive might help?
-- Randy Lovejoy, Americas, GA
Answer:
The active ingredient that you are talking about is phosphorus which is added through a component called ZDDP. For products that meet the new ILSAC GF-5 specification the phosphorus levels for the oil must be less than 800 ppm phosphorus. The ILSAC level for phosphorus has been reduced to protect the catalytic converter and other emission protection equipment. The engine manufacturers are confident that this level of phosphorus will protect both new and older engines. However, there are Mobil 1 synthetic oils which have a higher level of phosphorus (phos) and can be used in engines in racing or high performance applications; see the attached table.
So even M1 says to use there race oil for more ZDDP for more protection of things other than lifters. If I drove a Corolla I would get off the shelf oil, but I don't so I'll use the oil that has done a good job of protecting my engine.
ROD
