Somebody mentioned after market heads, that would not help. I would look into iconel exhaust valves and machining the guides for a looser fit. This has been necessary for years on high performance marine engines. The LS7 may need the same treatment because it is a pretty extreme engine.
The LS7 is an AWESOME engine. The best GM has ever made IMHO. However, in terms of power output when stock, it is no more extreme than the S2000, current Mustang GT, GT500, Viper, Challenger.....etc.
Remember stock it is 505HP and 7.0L. That is 72HP/L (yes, it is capable of much more, I know). Other engines operating at or above that power level are not having this issue, so obviously there is something going on here with GM's assembly, parts choice or a supplier issue.
It is not the design of the head but more or less the quality of the build. If you buy "assembled" aftermarket heads they can be much worse because the assembly can be really poor. The engine guy I use says GM leaves about 20 hp on the table in all their LS motors because of build quality. If someone were to pull the heads off and have a pro do the valve job over along with iconal valves the problem should be solved. It would also make a lot of sense to have aditional porting done to the heads at the same time.
OK, I wasn't thinking in the same vein. Yeah, a head that is purchased bare and then setup by somebody like Ed Curtis or he like is going to be a solid choice. A lot of the "OTS" heads aren't all that great in shipped form.
