Quote:
Quote:
Locally there is an AMC Javelin AMX that has an engine build by legendary AMC performance engine builder Herman Lewis. This engine is an actual AMC engine that develops around 1,000 horsepower at the engine. The car itself is a car built by AMC made mostly of fiberglass that probably was used or meant to be used in Trans AM or similar racing and now has been converted to a drag car. He calls it "Rare Breed" because of it being AMC powered.
The motor oil he uses is AMSOIL Series 2000 20W-50 racing oil. He has had experiences that solidify his belief in this product. Here's why:
He had a defective distributor gear and after replacing it he ran a petroleum 20W-50 racing oil temporarily to clean up the engine before switching back to the AMSOIL Series 2000 Racing Oil. His ET dropped consistently about 7 MPH top end and close to 1/2 second for the quarter mile. Every run was consistent but less than before. After he switched back to the AMSOIL Series 2000 20W-50 Racing oil his car went back to the old top speed and ET and was consistent at those speeds. Had to be the oil.
You engine sounds like it has the same problems as he does, with using racing fuel and very rich. With the 20W-50 viscosity you have enough viscosity built in for some fuel dillution so as not to have engine wear or damage.
That's my recommendation. Good luck!![]()
you dont think the 20w50 is too thick with those posted clearences?
what clearences is that AMC motor? is it N/A?
Im sure it could be a lil looser but who knows?
I had an issue with tight clearence and 20w50 2000 so now I use ASL in that application
If the Series 2000 20W-50 Racing oil was too thick, I would use the Series 2000 0W-30. But I was thinking about the possibility of fuel dilution and that's what the 20W-50 viscosity range was good for. The Javelin was running racing fuel and lots of it very rich. He has 5/8 inch fuel lines and consumes nearly 2 gallons of fuel per run. The 20W-50 would give some safety margin for fuel dilution. If fuel dilution isn't a concern, I would use the Series 2000 0W-30. It's in the same class of performance additives and would work great too.
