Originally Posted By: Mesozoic
Rod bearing clearance: 0.0024"
Side clearance: 0.022 - 0.030"
Main bearing clearance: 0.0025"
Piston/wall clearance: 0.0035"
Top ring gap: 0.022"
2nd ring gap: 0.022"
Deck height: -0.009"
The engine builder used Rotella 15W40 for its first fill and break-in oil. Since I have some on my shelf, I think I will continue to use this oil for about 5000 miles. Since the engine is full roller, do I really need to be concerned about using an oil with higher levels of ZDDP?
Don't care about the power output of the engine, it's a strong street/highway car and that's all it's for. For blown motors you definitely want less overlap, even a stock HO cam will do nicely. Just cut some brackets on the waterjet to make a Sanden compressor work with the blower snout bracket and should have updated A/C in there by the end of this week. Looking forward to that as it was 112*F today!
Not sure about your main/rod journal size, appears to me the clearances are nice.
Why not , if the ZDDP doesn't cost you extra over. Besides AW properties at cylinder liners and cam lobes/followers etc, it also has anti-oxidants and anti-corrosion properties;thus increased engine oil life and better protect against sludge/soot etc ...... all for free!
