Originally Posted By: Mesozoic
There's a lot of details on the combination, can't even recall everything without consulting the datasheet from the machine shop. The base is a Dart Iron Eagle 8.2" block, SRP 0.030" forged pistons, Crower billet steel rods, Cola forged crank, ported Edelbrock Victor Jr heads (2.08/1.60 valves), Gaterman roller lifters, Comp 1.7 ratio steel roller rockers, Crane 2031 roller cam, ported GT40 lower intake, the Blowzilla with Flowzilla manifolds, Accufab 90mm throttle body... I had it professionally assembled by Larry's Engine & Marine; he's done very good work for me in the past. With water/meth injection, I would estimate over 700 hp around 13-15 psi of boost.
I did all the computer tuning and harnessing work myself, as I've updated the engine so that it uses Ford's EDIS8 ignition (no distributor), along with computerized e-fan control, Siemens Seka 80 lb/hr fuel injectors, and water/meth injection control (AEM).
Someone asked about a bypass valve, yes, there is an integral bypass valve to help cool the air charge when not using the boost. The compression ratio of the engine is 8.5:1. Not sure of the rod bearing clearances or deck clearance, although they are written down on a datasheet filed away. Pistons and rings were all manually and individually fitted, file fitted.
Sounds like most people are onboard with the Rotella 15W40 conventional for break-in usage. I'll figure out what my bearing and piston clearances are set to and report them.
The 302 in my garage had a 2031 in it
You should put it on the dyno, see what it makes IMHO.
