Yesterday I took about a 9 hour trip in my 03 Audi A6 Quattro 3.0l. About 3.5 hours in the oil pressure light goes off. I pull over, don't hear in knocking, the oil level is fine, etc. I turned the car off for a minute, started it and when I put the car into "R" the light said okay. Once back on the road it did it about 15 miles later. At this point I stopped to get gas and did the same procedure as what I did earlier. On the interstate I maintained a speed of 75 - 80 mph.
Now I switched to smaller a road and cruised between 65 -75 mph. I did not see the light come on for another 140 miles or so. It went off, I pulled over, turned the car off for a minute and then headed on my way. Did it 15 miles later and then went another 80 miles before I got to my destination where it did it when I got off my exit.
I am running Castrol Syntec 5w30 that was put in the car 500 miles ago (first time its seen highway since switching to Castrol from Mobil 1) and the weather was between 27 - 35 degrees the entire day.
Any thoughts? Bad light? Can't be the oil pump can it?
