Car: 2005 Prius
Mileage: 28k
Miles on oil: 5000
Engine: 1NZ-FXE
Oil: Mobil 1 0W30
The computer is telling me that it is time to change the oil in my Prius. Basically it is just a countdown, when you hit 5K, it tells you to change the oil. I know that color is not an indicator of oil condition but I am thinking it is too early to change based on the picture below.
My question, do the 1NZ-FXE engines need 5k oci’s for the variable valve timing mechanism to function reliably? Is there any other reason I should not start doing 10k OCI’s in this car? I am using Mobil 1 0W30 with either a PureOne filter or a Mobil 1 filter depending on what is on sale at the time.
I use this car to commute to work which is about 70 miles a day, 60% Interstate, 25% county roads, and 15% city. I'm averaging 53+ mpg.
Mileage: 28k
Miles on oil: 5000
Engine: 1NZ-FXE
Oil: Mobil 1 0W30
