A good top-off oil?
Originally Posted By: Drew99GT
With that kind of consumption, I'd ditch Mobil 1 all together. Try a High Mileage oil, or simply a name brand conventional. 5K would be easy to do with any oil and that much top off.
WERD!!!
I have used Mobil 1 10w30 silver cap (for 90k) & now Mobil 1 High Mileage 10w30 (for the last 30k).... I got the vehicle used in '01 (65k) with 4k conventional changes before I bought it and it was in perfect health. But upon switching it immediately to Mobil 1, it was using more oil than I thought it should. I switched to high-milage Mobil 1 and it still will use about the same amount ( about 1qt every 3k).
As far as I am concerned, no healthy car should use a qt every 3k and upon reseraching this years before I joined BITOG, I learned of MANY MANY people online with the same issue; Mobil 1 burning of too much as compared to other oils.
I have never taken the time to change oils and see if it helps, but I finally got me some High Mileage conventional to try and see if it is really the Mobil 1. I do have 180k, but again, it consumes the same amount as when it has 65k so the motor is not worn out (especially on Mobil 1 for the last 110k every 3-4k).
And as far as top-off delima, I used to keep around an xtra qt of Mobil 1 for that, but I have found that Trop-artic syn blend is a good choice when bought by the case at Sam's club. You could use that OR Supertech if u wanted to top-off with full-syn, but the advice about keeping an extra 5qt jug of Mobil 1 is also a good choice...unless you want to try another High Mileage oil and see if it works better...I MYSELF DID NOT LIKE THE MAX-LIFE; my MPG went down and vehicle is sluggish. So far in my "other" vehicle, (non-Mobil 1 vehicle), I found it to run best with Pennzoil High Mileage conventional, so that is what I am gonna try in my 180k vehicle to in place of Mobil 1-High Mileage 10w30
Originally Posted By: Nick_Escalante
OK, I currently have 12 qts of Mobil 1 10w30 inventory. I was going to use some of it in the next change, but now I'm headin to AAP to get a new radio antenna, and I have the $10 off $25> coupon, so I was thinking of getting a 2 qts of PP to try out to get me over the $25 mark. This is all very confusing now since I've joined BITOG.
Save the Mobil 1 and/or PP for something that won't blow it out the exhaust. I'd be on the cheapest SM you can find. MAG-1? SuperTech? Dollar store brand?
NO LUCAS =( I LOVE M1 racing m4t superbike oil for topoff - its mobils' premium "real" synthetic and you prob: 1) burn less and 2) the engine power and smoothness benefit is enormous. Problem is its about $9/qt though my 5000 OCI interval topoff is less than a Pint. This oil "booster" saved me from dumping the Synpower I was disappointed with last OCI, smoothed out the motor and regained top end power and consistency of torque delivery.
It's run M1 for last 130,000 miles.
When did consumption noticeably increase?
Probably when his IRON levels went through the roof in his used oil analysis
Originally Posted By: FastSUV
... I MYSELF DID NOT LIKE THE MAX-LIFE; my MPG went down and vehicle is sluggish. So far in my "other" vehicle, (non-M1 vehicle), I found it to run best with Pennzoil High Mileage dino, so that is what I am gonna try in my 180k vehicle to in place of M1-HM 10w30
Though folks 'stay away from it in droves', I have found the redbottle QS higher mileage engine oil to work extremely well. It has no API rating, but engines love it. Dont like QS but love this stuff. AFA FastSUV comments on ASHLAND synthhetic - same here - engine(s)in which I trialed the lube ran worse than just about anything with a big mileage hit and lack of smoothness, torque and engine response.
OK, I got 11 qts of Mobil 1 10w30. I've got 8500 miles on current fill, and will change it out at 9000. I was thinking of running the next fill 12000 miles, changing the filter (pureone) at 6000. Try to get through the winter.
And I'm adding 1 qt every 2000 miles. Any thoughts.
