AND this:
The much maligned YouTube oil tests out there do show that there are, at the very least, differences in various oils. Many here have a visceral hatred of the videos and get irrationally hostile about them. The videos, though, DO seem to show that various oils have some discernibly different properties. Where the dubiousness comes in is when drawing conclusions about whether any oil is “better” than another based on any single string of error-prone testing.
That being said, perfect lab conditions are not necessary to ascertain reality. Imperfect sampling is still capable of constraining reality, just with wider error bars. As a geoscientist I can tell you that measurements within the natural sciences are chock full of error, and yet we still march forward. Its just a bit more challenging to work with dirty data.
I’m in the middle of compiling a lot of this data. In looking at it, a basic claim like “some oils have different properties than others” is not unreasonable. I’m noticing some loose correlations across the data.
For example, Amsoil does seem to have less evaporative loss than other brands when tested on the same day. This is likely to be real, and it fits with the general consensus that Amsoil’s Noak is indeed better than most other oils. Another example: higher tier offerings within a single vendor’s line do seem to fairly consistently produce “better” results in cold flow, evap loss, and wear testing. Again, this indicates to me that there is at least some real and valid information showing through on the tests.
My opinion is that, yes, there are differences. I do think that within a given vendor’s lineup, there probably would be measurably different performance between the bottom tier and top tier offerings that might manifest over the lifetime of a vehicle, all other factors being equal. However, I also think that there are an incredible amount of variables at play, and they are likely such small differences that they would easily be obfuscated by all the other confounding variables over the life of a car. Care intervals likely matter far more, for example.
When it comes to boutique oils, I am convinced they do perform better than off-the-shelf oils - especially in the ring areas.
What otherwise undefined differences do those YouTube videos show?The much maligned YouTube oil tests out there do show that there are, at the very least, differences in various oils. Many here have a visceral hatred of the videos and get irrationally hostile about them. The videos, though, DO seem to show that various oils have some discernibly different properties. Where the dubiousness comes in is when drawing conclusions about whether any oil is “better” than another based on any single string of error-prone testing.
Solidarity amongst geologists brotherThe much maligned YouTube oil tests out there do show that there are, at the very least, differences in various oils. Many here have a visceral hatred of the videos and get irrationally hostile about them. The videos, though, DO seem to show that various oils have some discernibly different properties. Where the dubiousness comes in is when drawing conclusions about whether any oil is “better” than another based on any single string of error-prone testing.
What do you expect to see in the results from a tool whose purpose is determining the suitability for continued service and lacks the resolution to make relative comparisons between products?But none of that relates to concrete demonstrable results in the many many thousands of used oil analysis we see here. You can educate me. Glad I created the discussion...lol
Blackstone has stated that they have looked at their data and see no statistical differences between oils w/r wear metals.What do you expect to see in the results from a tool whose purpose is determining the suitability for continued service and lacks the resolution to make relative comparisons between products?
I wonder how statistically deep they went. I bet the dataset is very messy and lacks the normalization required to really dig in. It’s likely very hard to accurately slice by the necessary variables to truly answer this question like car mileage, interval, age, make, model, date of test, oil brand, oil model, other metadata, etc. if the dataset is unclean.Blackstone has stated that they have looked at their data and see no statistical differences between oils w/r wear metals.
This is where I am on this. He has data showing differences...what oil properties are creating those differences (regardless of whether these meet criterion for ICE oil testing)? If he did these tests 100 times each I'd wager the results would be the same...some flow faster consistently by gravity when cold. Some 'boil off" more than others when heated etc. Why? What does that mean? What variables are an issue? It means something (I don't know what...it's a good question and may correltate to real ASTM oil test results...or not) and discounting those differences to being equivalent to taste etc. that folks often say here seems counter to being an inquisitive scientist and a bit of a cop out. I've seen some strange correlations that proved valuable in geological data sets for mineral exploration...The much maligned YouTube oil tests out there do show that there are, at the very least, differences in various oils. Many here have a visceral hatred of the videos and get irrationally hostile about them. The videos, though, DO seem to show that various oils have some discernibly different properties. Where the dubiousness comes in is when drawing conclusions about whether any oil is “better” than another based on any single string of error-prone testing.
The evidence seems to back up this statement, M! 0w40 gives the best bang for the buck.
What evidence is that?The evidence seems to back up this statement, M! 0w40 gives the best bang for the buck.
He can hear it. You wouldn’t understand.What evidence is that?
Maybe your generator needs an oil based rust treatment then.My generator also loved the 5W40 ACEA Valvoline. It got a workout the past couple days. Ran smooth and quiet loaded and hot. Stale fuel also.
Wear? It will rust apart before that is an issue
Also see dip stick color post as well as detailed exam of oil filter post for ASTM-level testing.He can hear it. You wouldn’t understand.
Then the engine may wear out first! What a conundrum! LOL.Maybe your generator needs an oil based rust treatment then.
