Originally Posted By: FrankN4
Originally Posted By: steve20
Frank
Your Tstat is a 195
Steve
I should have been suspicious as my temperature gauge hangs around 210 all the time.
If your Rado is anything like my Envoy, your gauges are nothing more than glorified idiot lights anyway. For example, the oil pressure sender has three outputs: 0, 40, and 80 PSI. The onboard computer takes the 40 lb output, looks at RPM and calculates that the oil pressure needle needs to be around 60 PSI. I wouldn't be surprised to find your temp gauge similar, using an input from the temp sender, and ambient temp sensor to calculate a display of 210 (coincedentally exactly where the Envoy runs also.....)
Frank
Your Tstat is a 195
Steve
