Originally Posted By: steve20
Remember the Honda filters are built to Honda's specifications, not the filter manufacturer's specs-same with Chryco GM and Ford
That is true, and makes me wonder why Toyota, for example, doesn't consider a high efficiency filter with a thread-end bypass necessary. Ford filters are reasonably efficient, and much more so, apparently, than Honda and Toyota OEMs.
Is it that they just don't care about any extra wear that might be caused by using a lower grade oil filter? Make you come buy a new car a little sooner? Seems hard to believe since they stake
their reputation, or try to, on quality and durability. A spokeman for Toyota recently told the press that current Toyota products were built for 300,000 miles.
So is Ford being too cautious? Do high end filter just not matter much? I am using so called "better" filters on my Toyota. Is the OEM just as good or better in the long run? I am taking it on faith and common sense that the filters I use are at least as good...but do they matter?
Honestly, I wish I knew.
