Oil Filter on Husky LT42 w/ Kohler 17 HP Courage
Kentucky
The stock filter is a Kohler 12 050 01-S1. The Wix cross reference is a 51056 for that filter. I've read where some replacement filters will not screw on due to differences in housing size. Just checking to see if anyone has run the Wix on this particular application to make sure it fits before I buy one. Thanks,
As long as it's a direct x-ref'd filter, you'll be fine. The Kohler Courage single cylinder engines only allow for the factory sized oil filter because of the way the filter is tucked up against the block.
Courage V-twins are a different story. You could go right up to a FL400.
Joel
I'm using a FL400S equivalent (ST 3600?) on my 20 Hp courage single.
I believe the 20 and 17 Courage singles share the same block?
More filter, less money.
Rickey.
Good to know you were able to fit one on a Courage single!
I was under the impression it was not possible because of the way they're mounted. Pic two in this link give a good view of the filter on a Courage 17hp single: http://www.brandnewengines.com/SV530-3221.aspx
I owned a Courage 20hp V-twin. Plenty of room on them to run FL400's.
Joel
Joel
What's a real curiosity is that the whole series (SV590-SV620)
http://www.kohlerengines.com/onlinecatalog/pdf/sm_20_690_01.pdf
Appear to be the same engine with horsepower rated from 19-22 depending on model.
Of course the 17 Hp is an SV 530 which is also covered by the linked PDF above.
The 17 is smaller inside, but identical outside; I believe.
Rickey.
Originally Posted By: 95busa
Different carbs
At one time it was as simple as the carb gasket!
(built in restriction)
Lets see.....if you carve out this little protrusion here....Hmmmm.
I sure hope NASCAR doesn't find our secret weapon. HeHe
My apologies folks I have strayed a little
Rickey.
