Ok WIX XP, Fram TG are designed to withstand long interval with synthetic oil filtering media.
Now I am using a Motorcraft FL500S on my F150 following the OLM. usually the oil change warning show up around 14500 km or if you prefer 9000 miles .
There is no mention on the Motorcraft filter that it is designed for long drain interval and that the media is specifically designed for synthetic oil. No wire mesh reinforcement either in that filter so.... Even if Ford recommend this filter would It be better to use a filter specifically design for long drain like the wix xp or the fram TG ?
