Nice graphic, BLS. Nice to see the evolution of oil over the years.
Since you are talking about cars in this thread, zinc levels went lower (the chart show that) shortly after the 1995 Federal Emissions Warranty law. Not a coincidence with respect to keeping catalytic converters from failing. Boron and Moly levels have been upped in many oils as the replacement for high pressure/temp areas (valve train specifically) that zinc used to be called upon to protect.
Question: How do you reconcile lower zinc content (for instance) in extended service 20,000 mile oil with the statement that more zinc only provides longer protection, not better protection like you shared? Looking at UOA's, zinc level is not being sacrificed appreciably in those oils with the long drain intervals. Saying lower zinc levels are associated with shorter lengths of protection would not seem the case. Can you share the study showing less zinc provides the same protection but a shorter interval that you are basing this from.
Back to motorcycles... For me the best oils consistently have been M1 10w40 4T and 20w50 VTwin with respect it staying in grade over 5,000 mile OCI's in a shared sump and the benefits associated with staying in grade. Not a temperature range those two won't cover in most any bike.
