Overview
My daughter's Rodeo has started using a quart of oil about every 400 miles over the last several months. Prior to that it used about a quart every 1,000 miles. The engine has 126,000 miles and I have used Valvoline MaxLife 10w30 and puralator one filter for the last 18 months. There are no leaks and it doesn't appear to burning it? The driving conditions are primarily around town and that has not changed.
I have been told the oil galleries in this engine are quite small and get blocked easily. I plan to add 8 oz of Kreen to the oil and run it for about 750-1,000 miles and do a change. I guess we'll see if that improves things. I also plan to replace the PVC as well.
The questions for the forum:
1, Has any one had experience with this engine and sudden oil consumption?
2. Is there an alternative route you all would suggest?
Thanks much,
Tim
Thanks much,
Tim
