Oil breaking in a 454
I always use a dedicated break-in oil on a fresh build. There's no disadvantage to it, and I've seen wear results in the first 250 miles being significantly lower than a conventional API oil, with or without a supplement. Oils like Rotella 15w-40 and Valvoline VR1 have shown 100-300 ppm iron after break-in. Driven BR30.... just 48 ppm.
Ok I picked up 7 qt Ravenol break in oil I will use running it on my engine stand and check so everything is fine before I take it to the dyno. Will change oil and filter before the dyno session will use dino oil when I dyno it and the first miles on street before I go syntetic.
I would dyno it on the same break-in oil. That's where the bread and butter of the break-in will be is on the dyno with varying load and rpm as well as heat cycling. Don't be worried about break-in wear metals circulating around. That's why you have a filter.
Driven offers their gp-1 in a break in SAE 30. I'd run that then switch to their 15w40 or 20w50 after break in.
Back in the day I usually broke in SBC's with non detergent 30wt and an appropriate amount of gm eos, then switched to Kendall GT1 20w50. Ah, those were the days.
I see no reason to use a 40 or 50 grade in a mild NA 454 making ~600 hp. A good synthetic 30 grade will get the job done without the increased hydrodynamic friction and accompanying power loss. We don't know the OP's bearing clearances though.
.003 on the rods and mains except nr 5 that has .0035. .020 rod side clearance.
street and some strip. Pro system custom 950 hp Holley car.
Oil pressure on most builds I have Done with same clearance is 25 psi@idle 900rpm and 50-60 psi@3000 and up depending on what spring I used in the oil pump(Std volym oilpump). Using 5w40 syntetic oil.
So 0w30/0w40 A3/B4 it is?
@wpod Thanks. I completely missed that somehow. :confused:
If I was building it, I would've gone .0020-.0022" on mains, .0022-.0024" on rods, and use a 30 grade. A lot of builders go wide though for added security. Given those clearances, a 40 grade would be needed. I apologize for that and ignore my comment on using a 30 grade.
