A mid tier oil, nothing special. Not saying its crap just not worth seeking it out or paying a premium in the US for it, there are many good and better oils that cost less.I see you are german any experience with Ravenol?
Your engine and most of todays components are very high quality. I so think about another boat and engine but the emotional part is just not there. It takes quite a lot of work to get everything working together and then the upkeep is brutal ! I go to the local drag track and watch the cars run and when the funny cars run I am happy.Ok so cam went flat and destroyed lifters? Solid flat tappet? Bearings went away in the roller rockers?
Im using Comp cams xd steel roller rockers(life time warranty) just couldnt justify the 600$ Crower for this build, billet hyd roller bullet cam and morel 4603 hyd roller lifters lifters.
The dyno guy has ravenol break in oil and use it and its not premium priced same as joegibbs amsoil, Lucas and other break in oils. Can pick it up today and its close to my house so tempted If you dont think its crap.A mid tier oil, nothing special. Not saying its crap just not worth seeking it out or paying a premium in the US for it, there are many good and better oils that cost less.
Plateau honedJust saying the cam is only one are of concern, we don't know the hone finish on the cylinders, if it was plateau honed then the concern is minimal but if its old school hone with high ridges it can be a real serious break in issue.
IMO there is nothing lost using a break in oil for a short time and the cost of it is minimal. JM2C
No its definitely not crap, its fine.The dyno guy has ravenol break in oil and use it and its not premium priced same as joegibbs amsoil, Lucas and other break in oils. Can pick it up today and its close to my house so tempted If you dont think its crap.
And you think that posting it here will be better how?All give different answers, just like asking what 10 people like for dinner. maybe they bought a flat tappet cammed engine and didnt break it in correct and used oil with not enough zddp?
When a lot of things work well then that usually indicates that it doesn’t matter. Which is what I suspect is correct in this case.I have used so many different combination,over the last 15 years I have built probably 10-12 hyd roller BB 454-496’s so dont know If it was luck or If it doesnt really matter If you use break in oil or just regular dino?
Thought asking wont hurt?
Very helpful! sorry that I posted.And you think that posting it here will be better how?
All the good stuff !!! I would bet.Plateau honed
I enjoyed finding out what you did to the engine,Very helpful! sorry that I posted.
Valvoline VR1 10W30 dino for break in and initial run in. Change oil and use the same oil for another 500 miles. Then Valvoline VR1 10W40 for life. High spring pressures and aggressive lobe ramps still need the extra zinc/additive protection.Has a fresh Chevy BB 454 I just built. Should be close to 600 hp.
Hyd roller billet core 160/420 closed/open spring pressure.
Moly piston rings.
Unsure what oil I should use during break in?
break in oil Like Edelbrock 1070, Joe gibbs etc. Regular dino 10w30? should I use break in additive like Comp cams, redline etc?
Why would you be sorry that you posted? Where are the sour grapes coming from? All I was noting was that your track record of getting a consensus here surely isn’t any more impressive than what you were getting before.Very helpful! sorry that I posted.
Yes, listen to Trav.Listen to Trav. He is a well respected and experienced mechanic![]()
