Nobody said that and is not written in the Stihl manual as well.That would not allow Red Armor as Red Armor is a synthetic blend. Wow, really?
Yes, now we are discussing only the Stihl BR800X 4-MIX blower and try to find the best oil for it. My last two posts are specifically for that machine which runs much low RPM and probably a lot cooler than a regular 2-stroke. You have experimented with thick oils that didn't work out well. I'm suggesting 2-stroke oils with lower flashpoint about 212°F and not higher than 250°F. All the oils you tested so far have much higher flash point than that and that contributes to smoking and not burning clean, especially at lower temps. Matter of fact the Red Armor has low flash point at 164°F.I'm not interested in what oils run best in 2 cycle machines. Only what runs best in a br800x.
I asked about your oil mixing procedure because you never mentioned at what ratio did you run any of those oils (Motul 710, 800, Amsoil Saber, VP Racing, what else did you run?) in the BR800. If you run ratios rich oil ratios above 50:1 any oil will get dirty and smelly. I've run the Motul Scooter Expert oil (above) at 50:1 in a 2-stroke bike and you cannot see any smoke even at start up. Yes, that oil is synthetic blend but is also JASO FD / ISO-L-EGD as the Red Armor and that covers your manual.
Also, please tell the moderators to add to your thread title and in your first post that you ask and discuss the Stihl 4-MIX engine BR800, not the Stihl 2-stroke engines.
