Japanese
$50 site donor 2026
I own 2-stroke Chinese string trimmer and three 2-stroke motorbikes. I haven't seized any of them even running some of them at 50:1.You have not ever owned and operated a Stihl 4-mix, right? Edit... So, what is your experience with 2 stroke ope? Brands and models?
Now, tell us how everybody run their 4-MIX engines at 50:1 with various both synthetic and synthetic blend oils and didn't seize them but you did with so many years of experience?
Let me guess—you measured the right amount of oil but adjusted the carb to run lean. Or last time you adjusted your carb to lean before running a thicker oil and then forgot to set it back to normal for the lower viscosity oils.
My question is still present:
Why did you temper your carb when perform tests of different oils and run the same ratios? How would we know about each oil burning and lubricating if you adjust the carb every time?
