Hello guys,
I've decided to replace every fluid in the car with fluids from Ravenol. I will also get additives for cleaning injection,cleaning radiators, engine flush. Is ravenol a good choice here?
I already chose engine oil, coolant, brake fluid and now I'm stuck at finding the best possible gearbox oil and power steering fluid.
For the manual gearbox (JR5), the manufacturer recommends TRANSELF NFJ 75W80 (APIGL4, MIL-L-2105 C or D). Here I think I have 3 choices (I filtered by APIGL4 and 75W80:
For the power steering fluid, the manufacturer recommends RENAULTMATIC D2. Here I think I have 2 choices (I filtered by Dexron II D and Dexron VI which should be compatible):
Which product do you think is better? Are there also other options I missed?
Also will I notice any difference in shifting and steering effort required?
Thanks.
- RAVENOL SSG Spec Synt LKW Getriebeöl 75W-80
- RAVENOL Getriebeöl PSA SAE 75W-80 recommended by their oil finder
- RAVENOL MTF-2 SAE 75W-80
- RAVENOL ATF Dexron D II recommended by their oil finder
- RAVENOL ATF DEXRON VI
Thanks.
