OCI with synthetic oil
Cajun Country, La.
1996 Toyota Corolla,121K miles
What is a good OCI change interval for this vehicle? I'm using Super Tech synthetic oil (10W30),Purolator gold filters,and it is driven 60% interstate,40% city.
It's hard to say with Supertech I haven't seen any used oil analysis on the oil. I would guess 5000 to 6000 miles on that oil.
I would go w/ the "Normal" service schedule in your owners manual. Just because you are using a syn doesn't mean extended drain intervals. Syn work best at the extremes IE Heat(Race Track) & Cold (Sub zero) thats where they shine, not on a daily driver. If you are looking for extended drains you need to step up to Mobil 1 Extended Performance or any Amsoil product that have the add packs designed for extended drains.There nothing wrong w/ the oil you are using it's just not designed for extended drains.
joe
I bet it has a weak add pack.
I would stick with 5-6,000 mile OCI's since the few reports I have seen do not list TBN numbers.
If you were gonna do 6k intervals on supertech full-syn, then what is the point of even using the synthetic? Why not do 5k on SuperTech conventional and call it good?
I saw the typical service it sees, but not the annual mileage. With this oil, if it's not too far above 12k, then 6 months would probably work.
