When I was younger I worked in a shop that built lots of stroked big block Chevrolets and put them in speed boats. All of the regular engine stuff, rods, heads, mains, etc got torqued and that was that but engine plate bolts that went through the bulkheads to mount the engines got flat washers on both sides, a lock washer on the nut side and then a Nylock nut with blue Loctite. The plate to block bolts, exhaust header bolts, bellhousing bolts all got safety wire. No wonder it used to take forever to set these things up.
