AndyM
Originally Posted By: SuperEd73
How hard is it to access that throttle valve? I don't know the engine very well but I know my sister owns a Maxima of that vintage and I'd like to make sure those screws are doing their intended job and not what it did to the OP.
Thanks,
Ed B.
You MIGHT be able to remove the butterfly without taking off the intake. There are 3 12mm bolts holding it in. If not, you'll need to remove the whole intake...which isn't to bad, but it is time consuming. It'll take around 2 hours if you are mechanically minded. There are 2 hidden bolts on the back that you can easily hit with a socket wrench, they are more annoying than anything.
Andy
Thanks,
Ed B.
Andy
