The E-core design is now part of the STP line and the filter's are a Dollar more than the same e-core's at Walmart.
It is kind of disappointing because I used to be able to get the Valucraft filters (e-core design) at AZ for 20 cents cheaper than the SuperTech Filters at Walmart.
Now, the same thing painted blue in a pretty box is a dollar more than the identical product at Walmart.
Now, the kicker. NO MORE VALUCRAFT FILTERS!
They have been replaced by... you guessed right... FRAM.
It is like the Wall O' FRAM in there, just like Walmart, except AZ has about 1/2 FRAM and 1/2 STP.
Then a little section for Bosch and Mobil 1. I might buy a few Bosch also, at $6.50 they have that silicone valve and seem to be a good construction. A buck cheaper than I can buy Napa Gold's.
Anyways, I might just go by Walmart and stock up on SuperTech filters. They are good enough for my Auto RX runs. And I might need some more once I get into the second clean and rinse phase.
Save the nice filters for when I switch to full synthetics after my 2 Auto RX cycles.
