Originally Posted By: 2way
Originally Posted By: SnakeOil
When I drained out M1 in the past it was a dark amber and was still transparent. The first and second Syntec runs I did had the oil coming out darker than Charlie Murphy's a**.
I have a different view on this.... I see it as Syntec doing a better job of cleaning than the M1 (and maybe even cleaning up after the M1). I've also seen 5W-30 come out darker than 10W-30 in the same engine on a similar change interval. The thinner oil does seem to do a better job of picking up/dispersing/carrying soot particles. The US Syntec grades seem to be on the light side (more below). I think they went that way, in part, to bolster their MPG claims.
I've been using Castrol products since '79. I was skeptical of the Syntec. However, I made the change from GTX in both of my cars. It did a tremendous job of cleaning out the second car I had bought used and I documented the tail end of the MPG gains (as well as multiple UOAs-which I think I have one posted here somewhere). I was seeing jumps of 1-2 MPG after each change w/the Syntec, till it finally plateaued considerably above EPA spec. Using it in the 1st car is bringing it's MPG back into line, too
I'm making the move to US Edge on the 2nd car and will see how it does (it doesn't strike me as much different than the Syntec, except that it has a PAO component). I will note that the plain US 5W-30 Syntec is on the light side and I still do an expedited OCI of 2.5K. It does appear to thin a bit, even @ 2.5K. As I do notice a difference after each OC. So, you might consider a mix of Syntec 5W-30/10W-30 or 10W-30 for higher OCIs.
Remember that this is dependant upon a lot of different variables which I doubt were constant during the two oil uses.
