quote:
Originally posted by tom slick:
just to add to what sws posted,
i've never seen or heard of a rod that is drilled with an oil passage to the small end(that doesn't mean they don't exist, i just haven't come across any). the ones i've seen that do squirt oil into the back side of the piston (for cooling on diesels) do it from the big end which squirts oil when the hole in the rod and bearing line up with the hole in the crank, it has a simple timing system. the small end of the rod has a bronze bushing that fits on the hardened wrist pin, it needs almost no lubrication so just a splash or vapor is plenty, it also doesn't move much, just a few degrees each way.
