Originally Posted By: JGmazda
Nice post! Soooo....assuming you can fit the larger filter, why would you go with the smaller filter? I've used both the NAPA GOLD and the P1. I think I'll go with the larger filter next time.
Also... Does anyone know if the NAPA GOLD 1356 has a larger equivalent?
I'm running the PureONE 14459 which is the larger diameter of the 14610, which is same as NAPA Gold 1356 (see my photos above). So if you cross the Purolator 14459 to the equivalent NAPA Gold you should have it.
Looks like a 1334 (NAPA Gold) or 51334 (WIX) = Purolator 14459.
http://www.wixfilters.com/filterlookup/results.asp?PartNo=14459&Submit=Search
http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=51334
The Beta Ratio on the WIX 51334 isn't great IMO. 95% efficient at 40 microns.
Beta Ratio: 2/20=22/40
Purolator Classic in this size is 97.5% @ 20 microns. PureONE in this size is 99.9% @ 20 microns.
