Don’t tell Stellantis; my Ram specifies angle torque on the front caliper bracket bolts. And they’re not reusable.Call me a hack but on trucks I typically just use my 24" ratchets to "torque" caliper bracket bolts. Give it good grunt, call it good.
Amazon. $121. If you wait long enough, you might find it for a bit less.Can I ask where you got it and how much? Good results so far?
WOW ! Thanks for posting that. I won't need brakes for a while but i would not have known that. I'll have to remember that in a few years.Don’t tell Stellantis; my Ram specifies angle torque on the front caliper bracket bolts. And they’re not reusable.
Unless it is a DD3 or something special like that torch it off.My $1 garage sale find. Brand is OIT and made in Taiwan. Chopped the broken open end off and now have another 15/16” I can put a pipe on. Nearly all brake chamber studs on OTR trucks are 5/8” which requires this size. I have several cut down like this either because they bent/broke or I needed a special wrench.
That’s ideal for sure but I don’t always have a torch setup with me.Unless it is a DD3 or something special like that torch it off.
Not sure about the 2500’s, but the 1500’s call for it.WOW ! Thanks for posting that. I won't need brakes for a while but i would not have known that. I'll have to remember that in a few years.
It will be an excuse to buy a digital angle torque wrench. Mine are clicker and a beam clicker.
I can never bring myself to trust those things. I've had one for years (not a Bosch) but if I'm measuring something, I want to see it on the tape.Picked up a new measure...
Amen! Punches, drifts and chisels are practically consumables. Always good to have multiplesFew new items:
Meyhew Punch/Chisel set. I really didn't need the whole set, only wanted the "starter" type punches but that set was 75% of the cost of this entire set. Can never have too many good punches.
Next are a couple of add on items to some bike parts I ordered.
Motion Pro Chain slack Tool, absolutely not needed, been doing it with a rule for over 20 years but it is slick and works well.
Tusk Feeler Gauge Set. Again I didn't need this at all, I have a set of Mitutoyo and a set of Starret as well as a few sets of Chinese feeler gauges. What made me spend the $10 on these is how narrow they are and they have "half thou" sizes in the range you would checking valves in.
Shoulda got the solarsCalipers, dead blow, and a straight edge.
View attachment 226249View attachment 226250View attachment 226251
In my experience that mititoyo’s go 5 years of almost daily on a battery.Shoulda got the solarsNever worrying about a battery again = priceless.
Still, nice haul!
Yep. I can't remember the last time I put a battery in mine.In my experience that mititoyo’s go 5 years of almost daily on a battery.
I use 'em everyday and I can! Typically run Energizer 357s.Yep. I can't remember the last time I put a battery in mine.
Nice calipers - have the same ones at home!Calipers, dead blow, and a straight edge.
