That Ford list has several CK4s - I think they were mainly concerned about dual rated SN/CK4 ones like this Supertech.CK-4 is supposed to be backwards compatible with older specs, but Ford officially had concerns with the reduced anti wear additives in that spec and released a list of oils they said where good enough for their diesel engines. Based in the oil analysis above, this oil has the amount of phosphorous that Ford wants, so I would use it. Since it's new, it probably isn't on Ford's list, if they are even updating it anymore.
https://parts.ford.com/content/dam/...iesel_Motor_Oils_Meeting_Ford_WSSM2c171F1.pdf
