I am trying to understand this assessment: the additives which are anti wear will actually cause more wear? As in sand against the reciprocating and spinning parts?
Too low of ZDDP and there's not enough P to film coat/protect the metal surfaces. This results in adhesive wear due to metal-metal contact.
Too high of ZDDP and it attacks the metal surface. Corrosive wear. The surface corrodes and the corrosion products get scrubbed away by the movement. Light bulb: there's a happy balance that avoids corrosive and adhesive wear.
The ZDDP is also being attacked by detergents, namely calcium. (ZDDP's job is to coat the metal. Detergents are there to clean it.) So lower ZDDP can still protect if the calcium is lowered, which you get to do if you substitute other detergents (like magnesium), and other anti-wear agents (like moly), and dispersants to keep the contaminants in solution. You also get to lower your ZDDP if you use formulations that last longer, so that you're not running thin at the end of the OCI. You also get to lower your detergent level if you assume modern low sulfur fuels aren't creating sulfuric acid in your sump, so you don't need to account for that in your TBN.
So it's simple. We reduce calcium and ZDDP in proportion, right? Add substitutes like moly and magnesium. Boom we're all oil formulating experts with tribology certs, a youtoob channel, and a nerdy t-shirt. Not so fast.
First, you need all this stuff to be soluble in whatever base oils you've chosen, which also need to meet your target viscosity, htts, etc.
Second, as you reduced calcium, which is not only a detergent but also has the added benefit of friction reduction, you realize you might want to use something like Boron for additional friction reduction without the detergent characteristic. So easy, just trade ZDDP/Calcium balance for Boron. Easy. (Well, only if all ZDDP, all calcium, all moly, and all boron is equally effective on a PPM basis.)
See, all these additives don't just have a single effect. Each additive does multiple things - some good, some bad. When you adjust one you create or remove the need for others. (I'm sure I have glossed over much in this respect.)
So why does this UOA of Supertech full syn look much different than some of the "lite" diesel synthetics with only 800 ppm Z and P (think Delo 5w-30). Does that make one better? Not really. The lite oils attempt to solve the same problem using different tools, and are perhaps easier on after treatment. (Ironically you might want to use a lower additive oil in your worn motor.)
What is Ford really accomplishing with the 1000 ppm P requirement? It's like saying you MUST have X quantity of moly to be effective, but not recognizing that different thiocarbamates are used. They all show up as moly on an analysis, but have different potencies/efficiencies per PPM.
Short reply - VOA/UOA doesn't really tell us everything about the constitution of the oil.
