New Scag SLS 42" Zero Turn!
Franklin County, PA
Had my Cub Cadet XT1 46" for some time now, it was great on the old property, but since moving in to my current house in 2022 I've been fighting with it. Mechanically it was fine, but with my yard I could never get a good level cut. After adjusting the (stamped) deck nothing would work. Altered my directions, nada. On a whim I walked into the local equipment dealer and decided to go with a Scag SLS 42" cut zero turn. Yes, it is a homeowner version and has non-servicable hydros, but for my use I bet it will last a good long while. It does have the 20HP Briggs and Stratton PXi twin. Not everyone's cup of tea, but it did pretty good. It still has the fabricated deck like in the Liberty, and the rest of the machine is just as solid.
Dropped off this morning (car was in the yard as I thought they were gonna have a trailer and I wanted to give them room to move around):
Never driven a zero turn before, so I puttered around the back yard a little bit. Despite the grass being super thick and slightly wet, I went for it. I usually do the front yard first, but decided to do the back first :ROFLMAO:
First goal was to not run over the septic riser, well head, or wind up in the road. Successful, and despite being a little clumpy due to being so thick, it cut really, really well!
It's going to take some practice, but I love it so far!
Run it a couple of years and suction out the OEM lube and replace with Amsoil Zero Turn 20w-50 fluid. Change it out every 3 years.
I guess I should have looked closer, but it actually has the CXi engine. Allegedly re-named commercial series? Time will tell how it will do.
Sharp blades do wonders from my experience. It looks like your terrain is an excellent candidate for a zero turn. Enjoy
How about a follow up how its doing since April? The CXi has fuel injection compared to the PXi, and more robust oil and air filtration. Very interested in the same mower. Would enjoy hearing a follow up.
This one is still carbureted, but definitely has the better air filter.
Has about 9 hours on it now, but I still absolutely love it! Mowing time has decreased a good bit. I can have everything mowed in an hour including trimming. I'm deeded .46 acre, but I mow the outlying area as the owner of that property refuses to mow it, so probably a good .6+ acre.
Changed the "break in" oil at 5 hours and filled it up with Rotella T6 15w40 synthetic. Old oil was definitely nasty.
I even went as far as buying a little trailer to haul it around in :ROFLMAO:
