As long as you dont have hills, you will like it. You can turn tight, just don't completely do a zero turn , it will spin especially on wet grass. do shorter 3 point turns. Its still way faster than a tractor type. Blade speed is there.
I'm on a 2013 time cutter 50 inch deck. The orginal deck belt lasted lasted 10 years, mowing 2 acres a time. I did rebuild the deck as the bearings went. But it mowed a lot of grass. That's all i've done other than 1 fuel pump.
When you get yours, check the engine speed with a tach, mine was slow, like 3200, had to bump it up to 3600.
