New Rider - Thoughts
Not that anyone here is waiting but…went ahead and closed a deal on a dealer Toro TimeCutter with fabricated 42 inch deck. I’ll ready to mow the flower beds down as I learn!
I’ve been using a 42” Timecutter (708cc twin) for 5 seasons. It’s been perfect, so far.
As long as you dont have hills, you will like it. You can turn tight, just don't completely do a zero turn , it will spin especially on wet grass. do shorter 3 point turns. Its still way faster than a tractor type. Blade speed is there.
I'm on a 2013 time cutter 50 inch deck. The orginal deck belt lasted lasted 10 years, mowing 2 acres a time. I did rebuild the deck as the bearings went. But it mowed a lot of grass. That's all i've done other than 1 fuel pump.
When you get yours, check the engine speed with a tach, mine was slow, like 3200, had to bump it up to 3600.
Stay away from " Toy Built". What a P.O.S. Has this huge honkin sticker on it " Made in USA " Mine is 3 years old. Been thru countless spindles, the tranny is already whining, ( and I don't go Nascar on it either ), ignition switch crapped out causing the starter to enage while engine running, so it killed the starter too. Burnt out a set of cheap Chinese headlight bulbs already, eats deck belts for breakfast. It's a good thing I'm handy. Could you just imagine sending it out to a repair shop when it throws a belt ? I don't even beat on this thing.!!!! Just poorly designed. Oh, DO NOT buy a machine from Home Depot, or Lowes, or whatever big box store you chose if the machine is OUTSIDE. Rainwater gets into the magneto/flywheel and rusts up EVERYTHING. Buy it off the floor INDOORS. You're wallet is you're limit, so do you're homework on the Internet.
Good to know. Thanks. The engine speed does need to be right to get the most out of the mower cutting performance. What engine is yours? Mine is the V-twin Briggs. I do have ditches with a slope. I’ll push mow those at least until I learn the capabilities and limitations of the Toro.
Replacing a 20 year old Craftsman riding mower. Looking at riders with at least 46 inch deck. 4 anti-scalp wheels on the deck is a must have (corners of deck). So far the possibilities are: Cub Cadet XT1, John Deere S140, and Craftsman T2400K. Any opinions and experiences are appreciated. Mowing Bermuda (I despise Bermuda).
Look at bad boy mowers or Ventrac. You didn't specify if you have steep terrain or not.
Check model # of Craftsman. 247 is MTD and 917 is Husqvarna. Avoid MTD.
I would go for John Deere.
Too old to learn zero turn. Budget is $2600.00 to $3000.00. This unfortunately holds me to the big box store mowers. Our neighbor has a Husqavarna. Nice looking piece of equipment but he has had multiple problems. Also it has the plastic transaxle housing.
It’s just like pushing a cart around the store.
Granted it’s a zero turn, but my cub cadet ZT2 50” has been great. Just hit 105 hours on it.
MTD is also " Toy Built" with a different sticker. STAY AWAY !!!! Made in America with Chinese parts. Sticker should say " Assembled in America using Global Parts"
OK, the TimeCutter will work. What engine? Break the engine in on conventional oil. After break in use a good brand synthetic as your regular oil. Change it every year or sooner depending on your usage. I run Amsoil Small Engine 10w-40 and change it each year. Do not wash it after each use. That just starts and increases rust. Use an air compressor and blow it off. Once a year I use Gunk engine cleaner and spray everything down and lightly rinse. Keep it dry when not in use.
Funny how folks keep making purchase suggestions after you told them what you bought. ;)
Others may stop by instead of creating a new thread... ;)
Plus, bragability !!!! LOL!!! ... which is why I'll hype up my 1995 JD GT275 with the Kawasaki single that runs smoother than the newer twins.
Much longer lived with far fewer maintenance issues than the Cub Cadet I bought new from a Cub/Kubota implement dealer.
I can still get a lot of the parts I need at the local JD dealer. I have also found over the years that the "expensive" JD parts last MUCH longer than the others, even other decently known brands.
The Cheap Charlie voltage regulator looked identical, but only lasted a couple years and took out the wiring connector on its way out ... which is still available at JD btw. ;)
Another thing I learned, not JD specific, shop the batteries by weight.
The same group battery for lawn and garden may weigh differently by several pounds. Getting the right battery really made huge a difference in ease of starting on this old rig.
I use the Batteries+ Duracell branded versions. Seem to work well for me. Recently installed a battery tender as well.
