If you are doing 5,000 mile OCI's with synthetic oil, a filter change every other oil change would mean a filter change every 10,000 miles.
I use synthetic oil; have since M1 first came out back in the 1970's. Always changed the oil and filter once a year, which usually, before I retired back in 2001, amounted to 18,000 to 20,000 miles. Of course, I added make-up oil as needed, usually 2 or 3 quarts. Never had any kind of problem with any of my engines.
I usually used 1 filter for the entire OCI; a couple of times, I did change out the filter at 12,000 to 14,000 miles. When I retired, I began to drive 5,000 to 6,000 miles a year, and I went back to regular conventional oil; just couldn't see wasting synthetic on a 6,000 mile OCI.
Now, I am driving about 10,000 miles a year, and have gone back to synthetic, using M1 High Mileage 10W30 in my 2005 Nissan Pathfinder. The present fill has 8800 miles on it, and I'll change it in December, when it should have 10,000 miles on it.
So, IMHO, your 5,000 mile OCI with a filter change every other oil change should be great. Don't forget that filters filter with greater efficiency as they are used, up to the time they are totally clogged. I have never cut open a filter that appeared to be anywhere near clogged. Your engine will probably enjoy better filtering in that second 5,000 miles than in the first 5,000.
Just my opinion derived from my 57 years of driving and car maintenance experience.
