dnewton3
Staff member
Consider this about the oil volume:
I presume the intent was to make a point about how a Harley only has a small volume of engine oil, so the "stress" on the oil is greater. But actually, we can see the topic point towards my argument! Everyone wrap your noodle around the following logic.
The 6.6L Duramax holds 10 quarts of oil. That equates to .66 L per quart of oil.
The 6.0L PSD hold 15 quarts of oil. That equates to .4L/qrt.
The TC Harley engine (depending upon size/year) is around 1.5L and hold 3 (is that right?) quarts of oil. That equates to .5 L per quart of oil. That is right in the middle of the two diesel examples. The Harley is right on par with the diesel engines as far as engine size vs. lube capacity.
So, the diesel engines hold about the same ratio of lube, and the turbo in a truck get's as hot as the head on a Harley.
Starting to see the similarities? Starting to see why dino HDEOs are a good choice for a great price? The operating environment for most any Harley is no more or less demanding that a typical late-model turbo-diesel light duty truck. Why would ultra $$$ PAOs be "neccessary" in a Harley?
They are a luxury. Use them if you "want", but they are not "needed" for the safe, proper operation of your Harley.
![21.gif](https://bobistheoilguy.com/forums/graemlins/21.gif)
