Do manual transmissions "sludge" up??
wytheville, va
I have a '94 Harley Davidson with a Dyna 5 speed gear box.
The bike has 16K miles on it now, and has been ridden rather easily from what I can discern. The previous owner said that for the last 7k miles it has been going into neutral on the downshift from 4th to 3rd gear every now and then. I've put 2K on the bike since I've owned it and I have noticed this happening on occasion.
I've asked on a few tech forums as to what might be causing this and the answers are as varied as the folks giving them; there is no consensus. I hear "bent shifter fork, something about the 'dogs', poor shifting technique, all the way to "Dyna 5 speeds just do that."
I think if it were anything bent, it would do it all the time, and it doesn't. It could be excessive wear on a cog, but the problem doesn't seem to be worsening as that scenario would likely entail. I do know of two other Harley riders who mention this problem happening on their bikes. One has been exhibiting the problem for about 20K miles (with 40K currently on the odometer).
My bike's transmission has always been run on Harley semi-syn transmission lube--at least up until about 1600 miles ago. At that point I switched to Mobil 1 75W90 to see if the downshift problem would go away. After going to the Mobil 1, I did not notice the downshifting problem for the first 1000 miles or so; it seemed to help. But now it's doing it again--every now and then, just like before.
My question is this: Is it possible that the trasmission is "sludged up" a bit? If I've read here correctly transmission lubes do not typically contain detergents, so this might not tend to keep the gear box clean. No?
I was thinking of changing the transmission lube out with a heavy engine oil which contains a healthy amount of detergent, and seeing what happens. Harley says that their 20W50 Syn3 can be used in the transmission. Amsoil recommends their 20W50 in the Harley transmission, as does Mobil 1 (V-Twin).
I've heretofore been a strong advocate of transmission specific lubes in the Harley gear boxes, but if it is determined that sludge could be the problem with my downshifts I might just change my mind.
Dan
The only time I saw transmission oil sludge was on an old Rambler. The oil was probably the original and 35+ years old. So I would say that it could sludge up in your application. When I bought my Sportster in 1992, the dealer said that it was very important to change the transmission oil and to use only their "Sport Trans" fluid. One good thing about Harleys is that the parts are reasonably priced and easy to find. Shouldn't cost too much to overhaul your transmission.
