My son called me and said he is having a problem when his 2004 Nissan Sentra 1.8 sits overnight and he starts it in the morning, he has troubles getting it to engage into drive. He shifts it through the gear range a few times and it will engage eventually. After the car warms up, he does not have problems getting it to engage into drive. No CEL and once engaged, everything shifts fine while driving.
The car has approx. 220k miles and I don't think the transmission has ever been serviced.
I figured a good place to start would be to change the transmission fluid and filter.
Does anyone have the service procedure and torque specs for this process? A little bit of searching seems like the valve body needs to be removed in order to change the filter.
Any other ideas what I might look for? It would be nice if all I needed to do was to change the fluid only. I only have a couple days to do this work. He is coming home for the weekend and needs to leave in a couple days to go back to university.
