Working on my son's '04 Nissan Sentra with 250k miles while he is back from college.
He was experiencing a few situations where the transmissionmission would have a little troubles engaging into gear at cold startup. Everything worked fine once he got going. I topped off fluid and it seemed to help a little.
This fluid has never been changed.
I am familiar with the concept and debate of not changing/flushing fluid when miles are this high when proper service has not been maintained, but I think in this case, I should roll the dice. I am thinking just a drain and fill, not a flush.
The fluid is a little brownish and has a bit of an odor that I would lean towards the burnt smell.
I would normally want to pull the pan to clean the magnet and inspect the pan to see what evidence there is about potential wear.
I have not had good luck changing pans in the past without leaking on my Expedition. Ended up having to use factory rubber or silicone gasket in combination with Hylomar Blue to stop leak. Factory gasket alone did not work (I did do extensive prep work and filed pan surface to make sure holes were not mis shaped) .
Looking for advice on whether I should pull pan (Which I would like to do, but more importantly, if I would risk a leaking seal by changing it and any advice on transmission seal... Dealer OE gasket, RTV, Hylomar).
