JHZR2
Staff member
Pulled the trigger today. Far better deal than I had thought.
What a great deal that was! Rounded up, that was $1.92 per quart.Pulled the trigger today. Far better deal than I had thought.
link?Kirkland 15W40 does have higher levels of zinc and phosphorus, specifically, 1270 PPM and 1150 PPM respectively according to the Warren Distribution PDS. Calcium is 1050 PPM and magnesium is 1000 PPM. The oil also contains a splash of moly 66 PPM. Overall, Kirkland 15W40 has a decent additive package, and it is slightly more robust than Walmart's Super Tech 15W40 blended by WD.
My wife made me buy 2 boxes of this oil on the last day of the sale. I was happy.Pulled the trigger today. Far better deal than I had thought.
What's not to like? Thanks for posting.PDF from WD for Kirkland Signature 15W40 HDEO attached.
Thanks for posting! - Looks solid.PDF from WD for Kirkland Signature 15W40 HDEO attached.
Oops... viscosity.I hope they come out with a HD 10W-30 vicosity.
This Kirkland Signature oil is dual rated for both diesel and gasoline. The “SN” API designation means it is approved for gasoline engines too. The Shell Rotella T4 is only diesel rated.Anyone using it in their gasoline car?
Thanks, yes i understand the dual rating labels and appreciate the response. I was more so interested if someone had any feedback or uoa after running an oci in their vehicle.This Kirkland Signature oil is dual rated for both diesel and gasoline. The “SN” API designation means it is approved for gasoline engines too. The Shell Rotella T4 is only diesel rated.
considering it is ck-4 it should at least have 1000ppm of calcium, zinc, and maybe phosphorous.Do we know if this has “elevated” Zn/P given these days’ reformulations? Considering this for my 5.9L Cummins... Other threads implied 1000-1100ppm-ish, but times change. It’s selling for $26.99 at my Costco, and my truck takes three gallons... good deal...
I'm not, but depending on the engine and climate, I wouldn't hesitate too. (My escape and Silverado would both be candidates for a summer fill. 15w is a little too thick for a Midwest winter, IMO.) This oil may very well see service in my OPE as well.Anyone using it in their gasoline car?
