- Joined
- Apr 19, 2025
- Messages
- 276
Air cooled Deutz diesel. 10L oil capacity.
Schaeffer's 700 15w40 SynShield has been used for years. Just put in the last of the oil stash and it's time to resupply. I'd like to switch to John Deere Plus 50 II 15w40.
The complication comes due to a slight oil consumption issue requiring an occasional top-off. Instead of buying another gallon of the Schaeffer's I'd like to make sure it's safe to use the Plus 50?
Looking at Schaeffer's data they call their oil a parasynthetic blend. What I've gathered is parasynthetic means a blend of PAO and mineral oil. First of all, I thought mixing PAOs with Group II or III was a bad idea.
Is there something about the chemistry of the Schaeffer's, such as some type of emulsifier, that allows for the blend? Will I upset the chemistry by adding the JD Plus 50?
- Thank you
- Thank you
