I've got a brand new rebuilt Toyota 2trfe in my 09 Tacoma 4x4. It currently has break in oil in there from the builder, afterwards he said go with Toyota spec, which for my truck is 5w20 or 0w20. The previous engine didn't fail however it had excessive oil consumption due to failed rings. It was upgraded with hastings rings and cp pistons and bored .20 over. I'm clear on the break in procedure, however I've been obsessing over which oil to use. Some days I'm just like screw it Mobil 1 cause that's what I used before other days I'm looking at "high end" oils ie amsoil although I don't like the fact I can't buy it off the shelf. Truck is used on very long trips often far away so availability is key. Truck sees all kinds of weather and temps, from -20c to +45c. Use ranges from highway to rock crawling, truck weighs in at about 5500lbs in full trip trim. I plan to stick with the standard 5k mile change intervals.
Opinions, recommendations appreciated
