New Darling on BITOG?
Originally Posted By: Ben99GT
Originally Posted By: Hethaerto
Seems like the 4-ball wear test is disregarded by BITOGers for some reason. I can't remember why.
I hear bleach also performs well in the 4-ball wear test. :)
As I have heard.
Not to mention the test is performed to oil at room temp. NOT at operating temp, so really the test is useless.
Amsoil is very good stuff though.
I am not knocking the quality of Amsoil as it is a well formulated oil . Just that Amsoil writes its literature for people who really do not understand oil. You can look at all those numbers and get no advantage from Amsoil when you change it before its time. $9.00 per qt oil and your car will last just as long as with $2.00 per qt oil. I just do not get it.
Originally Posted By: Johnny
No, if you use the good grease and seal up the engine, it will last a lifetime. Who's lifetime I don't know, but a lifetime.
The life of the Engine.
Originally Posted By: Drew99GT
My engine prefers Pert Plus over Head and Shoulders.
Yeah, but just wait 'til it gets dandruff...
I'm kinda thinking the same way as westcoaster (puts on flame suit)
I just don't think I could put my oil past 6k, regardless of what kind of oil I put in. If I could afford Amsoil, it would be in my car right now.
Being a car nut, I'll spend the extra money on my "babies"....
Granted, I'll be running that Napa syn in my cars, so I guess that will make me feel even better....
And shampoo :)
I'm going the other way with that....
TallPaul buys enough Valvoline to make up for me, who doesn't buy any.
So, the darlings are now Synpower (synthetic) and YB (conventional)?
I'd use YB if it weren't the most expensive conventional out there. I've used it before, no complaints.
These trivial pursuits here at BITOG.
Here is some more information about the "4-ball wear test" and why it is invalid for motor oil:
"D4172-94(2004) Standard Test Method for Wear Preventive Characteristics of Lubricating Fluid (Four-Ball Method)
Developed by Subcommittee: D02.L0.11
See Related Work by this Subcommittee Adoptions: DOD Adopted; ANSI Approved Book of Standards Volume: 05.02
1. Scope
1.1 This test method covers a procedure for making a preliminary evaluation of the anti-wear properties of fluid lubricants in sliding contact by means of the Four-Ball Wear Test Machine. Evaluation of lubricating grease using the same machine is detailed in Test Method D2266.
1.2 The values stated in SI units are to be regarded as the standard. The values given in parentheses are for information only.
1.3 This standard does not purport to address all of the safety concerns, if any, associated with its use. It is the responsibility of the user of this standard to establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
2. Referenced Documents
D2266 Test Method for Wear Preventive Characteristics of Lubricating Grease (Four-Ball Method)
B3.12 Specification for Metal Balls"
The test is designed for testing grease, not motor oil. Even though most oil companies use it to test grease and other machine lubricants, apparently only Amsoil makes claims that it has any relevance as a test of motor oil inside an internal combustion engine.
Originally Posted By: westcoaster
I know that Pennzoil Platinum has been the darling in this site, but it did land fourth in this test, beating Mobil 1 extended.
I think that we my have a new site darling in Valvoline Synpower?
Dude...put down the bong....
So is MPG increases, no matter how minute. It's impossible to increase fuel efficiency (around here).
So is the foreign oil thing .
You mean like GC? Or ACEA? I go with ACEA A3 primarily because it tells me the HTHS is minimum 3.5.
Too bad Maxlife Synthetic is so scarce as I bet it beats out Synpower on the dubious 4-ball test.
You must really think Amsoil is great stuff to change it at 5,000 miles .
Okay, I nearly spit my drink on the keyboard with that one...
x2!
No offense to the OP, zingers just need acknowledgement. I'm running conventional Valvoline right now myself.
put down the bong iwth the cat in it man...
ARX it
The 4-ball was designed to test grease. Maybe we should just pack the inside of our engines with the best 4-ball rated grease on the market and be done with it. Although that would get pretty expensive. Those greases that beat Amsoil on the 4-ball test cost on average $15.00 per tube. Someone else can do the math on this. A tube of grease is 14 oz and it would probably take at least 120 pounds of grease to pack an engine, depending on the size.
Next time I want to use motor oil in an application calling for grease, Amsoil will be my first choice.
but Head and Shoulders has more zinc! (seriously)
Good one!
